Mozilla 1.3 Beta released
Tobias Huber
15 Kommentare
Nach einem sehr ausgedehnten Alphastadium mit unzähligen Releases ist nun die erste Beta Version des neuen Mozilla Browsers erschienen. Sie trägt die Bezeichung 1.3b und steht sowohl für Windows als auch für Linux und OS2 zum Download bereit.
Hier die Neuheiten in der Version 1.3b:
  • Image auto sizing allows a user to toggle between full-sized images and images sized to fit the browser window. To give it a try, load a large image into the browser window or size the window to be much smaller. Now clicking on the image will alternate between auto-sized and full-sized.The feature can be disabled (or enabled) from the Appearance panel in Preferences.
  • Mozilla Mail`s junk-mail classification is mostly complete. Users can now automatically move junk mail to a spam folder.
  • Users can now "dynamically" switch profiles. To give it a try, from the tools menu select "Switch Profile..."
  • Find as you type, formerly known as type ahead find, has a new preferences panel (Advanced: Keyboard Navigation).
  • When installed, Chatzilla now has a normal Mozilla preferences panel.
  • about:config, the listing of most of Mozilla`s preference settings is now editable. Power users can now tweak just about every pref available without opening prefs.js in a text editor. Warning: tweaking some of these prefs may break Mozilla completely. Use at your own risk.
Alle weiteren Informationen findet man wie immer in den Release Notes.
